14bff vs. 14bsf - driveshaft length?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, May 6, 2002.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    My brother's rear end in his 89 Burb is making the dreaded Gov-Lock death noises and clunks! He was thinking of swapping in a 14bff in place of his current 14bsf (he has a 2500 Sub 2WD, 8 lug). What, if any, is the driveshaft length difference between the two rear ends - in other words, is one pinion longer than the other? They use the same u-joints, don't they?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    They will be the same length. U-joints should be the same also.
  3. kpanza
    Dec 8, 2000
    1,579
    Thanks, I appreciate it!
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Matt swaped out his 14sf for a 14ff just a few months ago and had no problems (other than the sheared center pin in the sf that prompted the swap).
  5. kpanza
    Dec 8, 2000
    1,579
    Oh yeah, that's right, Matt did it... Cool, I will let my brother know this...
  6. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I just finished swapping in a 10.5" FF inplace of the 9.5" SF. Vehicle is my '88 3/4 ton 4x4 suburban. The 10.5 has a SHORTER pinion than the 9.5" axle. I must have an extra 1-1.5" showing on my slip now than befor, kinda surprised me.
  7. kpanza
    Dec 8, 2000
    1,579
    Hmmm...that is interesting! Well, I will take your word for it, since we are talking about the exact situation that my brother would be looking at...except for the 4wd part, but close enough.
    I must be working too hard, since I totally forgot something! I could have just measured MY REAR 14BFF and compared it to his! Jeez...sometimes I wonder! ha,ha /forums/images/icons/smile.gif
    Thanks!
