??? 14bFF Wheel Bearing Nut Torque ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Feb 21, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Do I just snug these wheel bearing nuts down or is there a torque setting? What about the outer axle bolts... I should get a book, anyone have one scanned in?
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://community.webshots.com/user/borregok5> Pictures</a>
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=276891&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=276891&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    (Bows head down)... I should have done that.... I figure since I'm on here every day that I would have seen it go by...
    As usual, thanks HarryH3!
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    All the torque specs look good but it apears that somebody has been futzing in this axle previous to my aquiring it. Does this sequence look right for a spindle without the key but with locking washers...
    1. Oil seal
    2. Hub inner bearing
    3. Snap ring
    4. Hub outer bearing
    5. Keyed flat washer (no locking tabs)
    6. Adjusting nut toqued to 50, then backed to 35, then backed slightly to fit locking washer.
    7. Locking Washer with tangs fitted into above nut
    8. Retainer nut torqued to 65
    9. Shaft to hub bolts
    10. Axle shaft
    Does the non locking keyed flat washer look to be in the correct position?
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Yes. Inner nut-washer-outer bearing.
    Sounds good.
    Dave
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  6. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Cool, back to work then.. almost done... thanks!
