14bff yoke question?
Discussion in 'The Garage' started by PsychoticDeadGuy, Sep 5, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    Is the yoke pressed on or no? And does anybody have one near 680/80?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    The yoke is not pressed in. If you remove the pinion nut, the yoke should come off. Be advised, however, that the pinion nut should never be reused and that the pinion bearing preload should be reset (since this rear end uses a crush sleeve).
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It may not supposed to be pressed on buy mine would not come off without a puller. Not sure why but we had to drive it on with the old nut and then set bearing preload with the new nut.:dunno:
    Ira
