14Blt Brake Questions
Discussion in 'The Garage' started by 8t7jimmy, Nov 9, 2005.
  1. 8t7jimmy
    8t7jimmy 1/2 ton status Premium Member
    Mar 2, 2004
    137
    West Lafayette, Indiana
    First, is their any reason to run a 3/4 caliper over a 1/2 ton caliper? Also, i need to put new hard lines on the 14blt axle, (old ones are completely gone). What size line is stock and/or what size should I run? 3/16, 1/4, ...
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    i run 1/2 ton calipers no problems with 38 tsl tires on 1 ton. lock up fine:D and crossover lines are 3/16 size the tine stuff
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Aren't 1/2 ton and 3/4 ton the same calipers?
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    piston just a bit bigger on 3/4 ton units.
  5. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Uh, then I'm running one of each. When I bought my 8 lug front end it came with calipers too, but the bleeder was rusted and broke off in the caliper. I set them side by side and couldn't SEE any difference, and it stops fine. :dunno:
  6. 8t7jimmy
    Mar 2, 2004
    137
    Thanks for the info. I am going to run the 1/2 calipers in the rear, just so they match the front.
    With the 3/4 calipers having a bigger piston, should i use them in the front?
  7. sweetk30
    Nov 1, 2004
    25,546
    542
    the diffrence is minimal to look at. and for all we know the reman places might just pass off the 1/2 tons in the 3/4 boxes at times.
  8. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    I know this is a little off topic but i did the disc swap on my 14 blt. should i change ne thing else on my K5 or will it work ok if i just hook up and bleed the brakes again. I hear alot of talk about valves for proportioning and hydro boost and stuff like that. do i really have to get that into it?
  9. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    i heard the same stuff when i was doing mine but i just figured i'd try it and see how it works and i had no problems the difference in stopping power and distance was like night and day, no problems with the back locking up or anything
  10. 1HighK5
    Feb 7, 2005
    140
    New York
    so your sayn i could just use the same stuff i got with the new disc set up on the back with out ne majo problem or noth'n
  11. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    1highk5 - it's hit and miss with the prop vlave issue. The best thing to do is to install the conversion, bleed the brakes THOROUGHLY, and road test it. We have done this conversion on at least 20 different rigs and sold the kit to many more. We have yet to run into a prop. valve issue. But, I hear of guys that can't touch the pedal with them locking up the rears. Try it first, then figure out what you need.
  12. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    yea on my truck i set it up without any valves or anything just basically ran new hardlines from the T fitting on the axle to a brake hose to the caliper, didn't have any problems with rears locking up or anything on my k5
    when i did my buddies i was concerned about it because he had a longbed (less weight over the axle) but worked just as good as mine, both truck stop on a dime, couldn't be happier with the disc conversion
  13. 1HighK5
    Feb 7, 2005
    140
    New York
    Thanks I run it and see how it goes
  14. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Mine was not that bad after the swap, but it would lock up the rears almost instantly if it was raining. I just installed an adj. prop valve from Wilwood. Works great now.
