14blt ff spiderball
Discussion in 'The Garage' started by jekquistk5, Mar 15, 2006.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    All,
    My toyota friends and jeep friends dont think I have enought metal when I welded up my spiders. Let me know what you think. I did it like kidjethro..
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    that oughta work. I put a little more than that into them though. I usually try to fill ever nook and cranny I can.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    My buddy welded the whole thing so it looked like a softball,then grinded everything smooth. The whole process took him about an hour :eek1:
  4. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I might do a little filler work then. But I made several passes. I used 6011 rod, so its a hardened rod. I think it should work but I guess I'll fill a little more. anyone else??
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    whats with all the rust?
  6. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    ask emetology101.. they were his spiders, but most of that is slag, that I still have to clean up. and burnt 80-90
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    ah very good, id try and fill it up some more.
    just my .02, but if the weld breaks id bet you're screwed, so filler up
  8. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Allright will do. I figured Id get some full size advise before I take advise from a j**pr
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You did several passes?? Looks like just tacks to me:confused:
    Fill it all in with good beads........please:D
  10. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Please inform me on what welder you are using if those are just tacks...
    but yeah i'm going to fill it in more...
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Theres only like 2 teeth tacked......sure you have the right picture up?:rolleyes:
  12. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    So what all of you are saying is to do this.. and do not even pay attention to the way Kidjethro did it.
  13. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    The teeth are filled/blended together. I guess its just a bad pic, I'll take another one later.
    Does anyone have any pics besides the jethro ones... So I can compare
  14. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    This is my old Gov Bomb after MNorby hit it with his Miller for about an hour :D He did the same thing for my 10 bolt, and my 70, and my 60..... I owe him a spool of wire and a 12 pack of beer :)
  15. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Ok... so the whole idea is to increase the weight of your rear axle by about 5 lbs..lol
    I'll take a better pic tomorrow(camera is charging), I guess the pic is bad because I didn't take the slag hammer to it yet, so what looks like rust/teeth is actually a weld.
  16. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    No, the idea is to penetrate well into the metal all around the teeth of the gears where they touch. If you have teeth interlocked that are not welded, then you should weld them... Lay a clean bead, and then clean it up more when you are done.
  17. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I understand that the teeth need to be welded pretty good, and I think they are, Its just my picture doesn't do it justice.
  18. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    See where the spider gears touch the side gears? You have AIR gaps between the gear teeth there still, and it appears that only the outer teeth of the spider gears are welded at all. You want to see solid steel anywhere the the spider gear teeth even come close to the side gear teeth. :)
  19. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    That spider was nuked!
  20. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Now thats how you weld a spider:waytogo:
