14blt ff Welding (spider ball)
Discussion in 'The Garage' started by jekquistk5, Jul 11, 2005.
  1. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Everyone is telling me that the way the tech article welds the spider gears is not going to work for long. Now I remember someone talking about the spiderball metheod. Does anyone have a right up or atleast some pictures on the spiderball. A friend is willing to weld my rear end as long as its not the star technique. This is a trail rig only with very little road driving. So I'm not worried about that. thanks
    Jess
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    PM Kidjethro. He had a good write up with pics at one time.
  3. metto
    metto Registered Member
    Jan 17, 2005
    64
    Raleigh, NC
    tack all of the spiders together while they are still in the carrier. pull them out, put some scrap steel inside and start burning it together. go slow and take breaks so you dont distort them too much. when you are done it will look and work like a mini spool
  4. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Allright I PM kidjethro, hopefully he can get back to me. My friend really just needs pics if anyone has em.
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I had printed out pictures from Kidjethro's post when I done mine. I can't never find the original post because he didn't start it.
  6. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I found this post but no pics
    Click me
  7. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    Found This a while Back
    I believe this pics are KidJethro's not positive but I am almost sure.
    Hope this helps.
  8. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Thanks those are great!!!
    :bow: :bow:
  9. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    That was the post and those are the pics.
  10. BlkDirtyMax
    BlkDirtyMax Newbie
    Mar 21, 2011
    Michigan
    Can you guys think of any reason those pictures won't open up for me? I would really like to take a peek at them, as I am ready to dive into my 14-bolt and start welding. It'd be great to have some pictures to refer to. Thank you for your time!
  11. Orange85
    Orange85 1/2 ton status
    May 10, 2009
    262
    Wisconsin
    Have to be a member to view attached images.
  12. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Basicly the idea is NOT to just fill in between the teeth. Weld everything to everything. Spiders to cross shaft, spiders to side gears. Cut some plate to shape in between the gears and weld that to everything. It will look like a solid ball when done.. I'll post a pic tonight when I get home if nobody beats me to it.
  13. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Wow to think I wasn't competent in welding my spiders back then...:haha::haha::haha:
  14. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Also take your time while doing it don't crank it up and go to town. If you don't you will end up with spiders that will not fit into the carrier.
  15. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    x2!! :deal:
    I started with one side gear in the carrier and the spiders on the cross how it will sit inside the carrier. I tacked everything like this then removed it to weld. Checking periodically to make sure it still fits inside.
  16. NorCal_Chris
    NorCal_Chris 1/2 ton status GMOTM Winner
    Sep 25, 2009
    2,946
    33
    Sacramento CA
    this is what i did
    used an arc welder and went to town. Tacked the spiders together then made sure it still fit, then welded all aroudn the spiders then made sure it fit. Then i got a bunch of scrap peices of metal and wedged them in and then let it have it with about 10 rods. It was red hot but it didnt warp, fit just fine back in carrier.
  17. mudbuggy
    mudbuggy 1/2 ton status
    Jun 10, 2010
    631
    Indianapolis, Indiana
    Holy ****! You got problems if that breaks loose!!!
  18. 79bonanza
    79bonanza 1/2 ton status Premium Member
    Mar 31, 2010
    1,668
    274
    Georgetown, Kentucky
    X2 thats not goin anywhere
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    Wow! Holy welding rods Batman! :eek1::eek1::eek1:
  20. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    HEY!!! I thought that work bench looked familiar.:haha::haha::haha: Those are my pictrures. That's the set I made. It wasn't done with a stick. I used a 220 Lincoln mig, 035 wire.
