14blt plug weld
Discussion in 'OffRoad Design' started by mtnman, Oct 14, 2006.
  1. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    Hey Stephen, I want to re-weld the plug welds on the other side of my 14blt to make it almost as good as the side you guys fixed. How do you guys cut out the original weld and how big a hole saw do you use? thanks again for the help and for sure next year I'm buyin' the ORD crew a round!:bow:
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    The only time I have had to remove them they were litterly falling out.
    I drilled a 1" hole with a hole saw for 1 new location but I think several 3/4" holes in addition to the existing ones should be good.
    If you want to remove the existing plug welds I would use a torch and be real careful as you melt out the weld.
    To drill new plug weld holes.
    Just take a regular hole saw with the pilot bit in it just set real short. Drill untill the entire holesaw is cutting into the cast but the pilot is not into the tube yet. Then remove the pilot bit and run the hole saw slowly in the groove it started, this should keep it lined up and not let it walk around on you. The chunk of cast should fall out and let you get a nice new plugweld in.
  3. mtnman
    Sep 8, 2005
    2,087
    31
    Thanks man, I really appreciate your help! Looking forward to wheelin' with all the ORD crowd again, you guys are great!!!:bow:
