14bolt carrier
Discussion in 'The Garage' started by cegusman, Jul 5, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Can i put 4.88 gears on a carrier that had 4.11?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yes, but you'll have to buy gears made specifically for that situation. The carrier break on a 14-bolt FF is between 4.11 and 4.56. You can buy 4.88's made with an extra thick ring gear to make up for the difference.
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thanks, do you no of any writeup for the install of the gears?
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Ask thatk30guy, he might have done a write upon it.
    -- Mike
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Strangely enough, it's probably easier for you to go over 4.56 than it is for me. When I was sniffing around for 5.13s, I found out that everyone had them in "thick" gears (what you need on a 4.10 carrier). But I couldn't find them in "standard". I had several (including Randy's) tell me to switch to a 4.10 carrier! One place claimed to have "OEM gears" but I have no idea whether that was real or not.
  6. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Check CK5's tech page. There is a writeup there.
