14bolt dics brake spacer
Discussion in 'OffRoad Design' started by tweaker, Jan 13, 2005.
  1. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    how much is the 14bolt dics brake spacer just by its self? i already bought a thick 3/8" bracket and the little sleeve spacers seem to be a bad idea for the mud.
    thanks
    Dillon Carson
  2. tweaker
    Mar 21, 2004
    263
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Can't do anything with this one right now since I'm at home and all my price info is at the orifice but I can take a look on monday. I'm going to guess that the spacers are about half the kit or a squeeze less since they use a good bit of cutting and a bunch of starts and stops. I'm going to guess $60.00 for the set?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    $60 is good, let us know if you want them.
  5. tweaker
    Mar 21, 2004
    263
    thanks steve and denise. my heart has stop beating so fast, and things are good now. just a little mistake, that BAM. took the cake. your timely responses are the diference in todays market place, and i look forward to further dealings.
    thanks
    Dillon Carson:D
  6. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i dont like those spacers either, they see alot of leverage with a small surface area. i know most people probably run them with no problem so there probably fine. i machined my own caliper brackets, they will be bolted to the flange. that moves them inboard .75 in. i machined a aluminum ring spacer that goes between the hub and rotor. studs press thru spacer into hub, there is 16 holes in the ring, 8 for studs & 8 taped to bolt rotor to. all on same bolt circle ofcourse. the bolts holding the rotor will have crimp nuts between the hub lugs for extra hold strength. shouldnt be any problems. i will try and post pictures, but i dont have a digital camera. i can borrow a buds though.:)
