14bolt----Disc brake pics!!!
Discussion in 'The Garage' started by or2play, Sep 15, 2002.
  1. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
  2. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Brian,
    Do you think it makes a difference where the caliper is located?
    I notice that yours is substantially "clocked" up compared to where mine ended up being.....Your's looks to be in about the 11 o'clock position, mine are at about 9 o'clock....?
    Dunno if it make a difference in braking, but might have some issues when it comes to bleeding the brakes.
    Because there are only 4 holes in the bracket, it would seem that there are only ways to install the bracket. In reality, you can also "flip" the bracket too, which means there are a total of 8 ways the bracket can be bolted to the axle tube. This is what I found on mine anyways....
    Curious /forums/images/icons/tongue.gif
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Its purrrdy. Do you think there will be any issues with the rubber brake line when the rear axle is flexing?
  4. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    Mine are about 11 o'clock. I actually wish I put them on the other side, about say 2 o'clock so they match the front brakes. But I haven't seen anything yet to suggest clocking them one way is better than the other.
    When I get my springer setup, I plan on pulling the brakes off and flipping the bracket the other way. Well see then if that makes them stop better or worse.
  5. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    I'm sure there would be. Right now the truck stays on the road. Those brake line were a quick fix to get me on the road. When the suspension is done I'm gonna half to get longer ones anyways.
