14Bolt FF/10Bolt hard lines
Discussion in 'The Garage' started by CHEVY 4WD, Jun 11, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ive been posting ALOT over the past week or so but this is al vital information and this I tryed a few serches on and found nothing. Are the hard lines from a 14Bolt FF and 10bolt close to being the same? My 14bolt dosent have any hard lines on it and I got the old 10bolt lines I could take off But is the line and ends the same size? I know it probably wont fit RIGHT but if it can get me a few months I will then be able to get new 14Bolt FF lines
    BTW I appreciate all the help and I WILL get a membership SOON /forums/images/graemlins/thumb.gif
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i assume you are talking about the brake lines- and yes they will fit. i believe the 14FF uses larger diameter tube, but without a 3/4 ot 1 ton master cylinder it won't make a difference. but yes, the flare nuts match up.
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Well actually im putting a 1ton mastercilinder on BUT if it will work for a few months then Ill be good to go BTW are the 3/4 and 1ton 14Bolt lines the same?
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    the LINES i don't think are, but the flare nuts are.
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Money is tight for me too, but hard brake line is really cheap. Do brakes right the first time....
