14bolt FF disc brake ?
Discussion in 'The Garage' started by mostwanted, Jan 24, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I am considering swapping in disc brakes on my 14 bolt while I am rebuilding it. I have tried searching, but I am haveing a hard time comeing up with what I am looking for.
    Which brakets use the GM calipers and which ones use the caddilacs? Also could I get one that matches what I run in the front, so I only need to carry min. spare parts?
  2. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,193
    356
    Ridgecrest, CA
    The 3/4-ton truck front calipers are the same size (bolt pattern and radius)as the ElDorado calipers. Any aftermarket disc-conversion brackets should work.
    I personally like the ones from Dunks Performance. They are the only one-piece units that I know of (the rest have two pieces bolted together to get the offset right).
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
