14bolt ff disc
Discussion in 'The Garage' started by Wally81k5, Mar 14, 2003.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    hey everyone. I have a question. When doing a disc conversion on a 14 ff what rotors do you use and what calipers? also i seen there is a hub to be pressed into the rotor? I think...
    also could anyone lemme know the dimensions of their brackets and the size of the 4 spacers?
    I assume that the spacers and plate bolt into where the old backing plate from the drums was?
    Any body with info that would be great.
    Thanks. Ryan
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You use 3/4 ton GM rotors. Use the 77-79 Cadilac Eldorado calipers if ya want to retain the e-brake. If not, you can use the 3/4 GM calipers too. The hub from the 14b gets pressed into the 3/4 ton rotor. As far as the brackets...there are numerous people on this board that sell them...Along with the spacers. Usually between $70-$90 depending on the person. And yes....The bracket and spacers go in place of the old drum backing plate. /forums/images/graemlins/thumb.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Caddy calipers are 76-78 Eldorado, not 77-79.
  4. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    Cool, well that makes sense. Thanks for the replys.
    I know alot of people sell the brackets but i work in a metal/machine shop so i as just looking for some dimensions so i can make a set of my own.
    Anyone help me out?
    Ryan
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    make sure they are forn an eldorado, the seville ones look very similar, actually the case is the same. there are two differences; the piston heigth and ebrake brackets. I peronaly have and use the seville brackets. i have pics if you want to compare.
    ARQ.
