14BOLT FF hub question :Please Read: part 2
Discussion in 'The Garage' started by CHEVY 4WD, Aug 7, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ok if you read my first post about this you found out im a idiot because I dident have a spindle washer. Well now you guys gotta tell me why im still a idiot I got the washers today put them on well one side is GREAT but the otherside does the same thing moves all around on the hub I replaced the inner bearing(agin) and race Hoping this would help but of course it dident. Im really getting tired of throwing money at it and nothing coming back out can some one PLEASE help me agin? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
    If nothin I said makes since bacially the hub wont tighten down one 1 side
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ok and when we put the hub on...and when it moves, it seems like the outer bearing is staying still, and the hub is moving around it? anybody had this experience? im sick of him throwing money at it and nothing coming back out /forums/images/graemlins/grin.gif /forums/images/graemlins/1zhelp.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Well, I hate to be the bearer of bad news, but since you say you already installed the washers first and still have movement.............. /forums/images/graemlins/frown.gif
    I'm gonna go ahead and speak from experience that you may have a bad bearing hub. By this, I mean the machined surface where the race sits may be worn out and therefore causes the race to sit too far inboard. With the race sitting too far in, the nuts can be tightened as tight as you want and the bearing hub is still gonna move in and out slightly.
    The easy solution/fix to this problem is to find another replacement bearing hub that has no worn race seat. /forums/images/graemlins/frown.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    im gonna go to a bearing shop today at lunch if i can and see if they might have a shim or spacer that could go behind the outer race and push it outwards some, i never heard of a race shim or spacer until last night and it sounds feasable...i figured it was in the hub since the one hub does it on both sides and the other is fine on both sides...
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    theres no other way? /forums/images/graemlins/confused.gif I got to much money in these hubs to trow them away (machine work)
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    1-Have you tried both hubs on the same side of the axle to see if the hub is good?
    2-After trying #1…if they both fit good then it’s your axle housing..
    3-If the one still is loose, check the washer thickness the depth of the race bore and the walls for scuffing…
  7. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    You've had both wheel bearings out of the hub, right? If so, check to see if the outer bearing is reinstalled/seated correctly.
    The outer bearing and race should be installed first and then a large snap ring goes on the inboard side of the race. Once the snap ring in installed turn the hub over and use a punch to push the race back against the snap ring.
    I don't know if this is your problem but I do know that the outer bearing is a tricky install since the 14 bolt snap ring set up isn't used on other axles.
    Does the hub appear to be seated in it's correct postion when compared to the opposite side? If not, look for any burs or scoring on the spindle. The spindle may not necessarily be bad but it may have a mark on it preventing one of the bearings from sliding all the way into position (hence the nuts bottoming out on the outer bearing and the hub still moving around).
  8. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Oops, looks like I clicked one time too many. /forums/images/graemlins/crazy.gif
    I'll call this a pad post on my way to 1k! /forums/images/graemlins/grin.gif
  9. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    999 post on the board, 999 posts! /forums/images/graemlins/thumb.gif I'm such a loser /forums/images/graemlins/thumb.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, I did fix the problem bearing hub I had once, and its still on the road today, under a different truck that I sold out.
    What I did was simple: I got a spare washer (the one that goes on first before the inner spindle nut) and ground the little tab off that slides onto the keyway slot. Basically made it an actual round washer without the tab. By grinding that little tab off, you allow the washer to slide past the ends of the threads so it will tighten up the bearings. Use the regular washer after this modified washer and then the inner nut, tang washer, outer nut. Should be good to go after that. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
    Disclaimer: I still highly recommend you to find or locate another bearing hub that is still good and not worn. While my fix for the loose bearing hub is not guaranteed to last forever, I still would rather replace the bearing hub and know its good rather than knowing it was "fixed" with that modified washer. /forums/images/graemlins/thinking.gif
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Thanks guys Im gonna replace the outer race and bearing(never did just the inners) if it still dosent work then Ill grind on the washer and start looking for another hub. At a local speed shop they told me they could put some rear end shims behind the inner race
    does anyone have any pix of those snap rings?
    Does it go in from the top? I did notice that the outer bearing always twitst up when I try to put the hub on on that side does it go on jus like the snap ring on the front end(before the locking hub)?
  12. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
  13. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Unfortunately, I don't have any pics of the hub set up.
    The snap ring is not like the front at all. The outer bearing goes into the hub from the inboard side (the opening on the outboard end of the hub is too small for the bearing) in this order: bearing (taper pointed towards the seal) / race / snap ring. Once the bearing and race are installed put the snap ring in, there is a groove in the hub for it. After the snap ring is seated, flip the hub over and drive the race back against the snap ring.
    The outer bearing will move around during installation because it's loose just like on the front wheel bearings. Once the hub is on deep enough for the bearing to slide on the spindle it will straighten up.
  14. TONYP
    Aug 13, 2002
    2,116
    so cal
    do you need pic's of the hub...I have mine out so I could get you some...did you try the hub on the other side?
  15. Confedneck
    Nov 1, 2002
    5,236
    read my post up that way...we tried both hubs on both sides, one is fine on both sides, the other is crap on both sides, and if we forgot the snapring on one side, chances are its not in the other side either..btw it is setup for disc brake conversion so it has 3/4 front rotors bolted to the hub instead of the normal drum, i remember taking those snaprings out when we pulled the drums off but i dont remember if we put them back in...guess thats tomorrows job eh?
