14BOLT FF outter race
Discussion in 'The Garage' started by CHEVY 4WD, Sep 12, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I made a post a wile back somewhat to do with this... but now my problem is back, my outter race keeps sliding in so I pounded it out and it worked for a few days then the hub will loosen up agin. Im gonna change the outter race tonight but I dont think its gonna help any. Does anyone know if I have to take the inner bearing race and seal out? and I pound the outer race inward to change it right? Also some one told me I have 2 peice hubs this insent ture is it?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If the race is moving in the hub, you need a new hub. That one is apparentely trashed.
  3. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Yup, sounds like a spun race/hub. If you can move the race around or spin it while its 'pressed' in...the hub is worn and needs to be replaced as said above.
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the race doesnt spin by hand..it just walks inwards (to the inside of the truck) when you drive, i suggested to go to a bearing shop with the race and get some spacers or shims that fit between the outer race and the flange that it rests against, to keep it from sliding in...whaddya think?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    14 bolt hubs have a big, beefy locking ring that clips inside the housing to hold one of the bearing races in place. Do you have that installed? /forums/images/graemlins/eek.gif Without it, the bearing race will move around.
  6. Confedneck
    Nov 1, 2002
    5,236
    almost like a snapring right? i knew he was missing it, but he insisted i was wrong, if anyone has a picture of it, post up, because i know exactly where to get it...
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep! That MUST be installed or the race will never stay in place! /forums/images/graemlins/eek.gif
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Ok, the proper way to install the bearings is as follows.
    You need to install the outer most bearing and race first.
    (1) Drop the bearing into the hub with the taper of the bearing facing the frame side of the truck.
    (2) Next install the race so that the taper surface of it is facing out toward the wheel.
    (3) Now install the large snap ring in the groove.
    This is where some people get all screwed up.
    (4) You must now drive the bearing and race inward against the snap ring.
    Now that you have the outer bearing installed you may start on the inner but I am not going to go into detail about how to do that one since your problem is from your outer bearing not being installed properly.
  9. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    thanks guys the weird part is 1 of my hubs dosent have any problems and neither have the snap ring... anyone have an idea where I can find those on a saterday? /forums/images/graemlins/confused.gif
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    At a salvage yard. /forums/images/graemlins/thinking.gif
