14Bolt FF VS D60 FF
Discussion in 'The Garage' started by CHEVY 4WD, May 20, 2004.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ive been reading and ive noticed some people prefer the D60 FF over the 14Bolt FF, and I was really just wondering why? Is it lighter? Stronger? I know there are more locker options but is that the only reason people like it better? /forums/images/graemlins/confused.gif
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    gear choices that's all I can think of
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Gear choices and I'm sure its lighter. Got to be weaker though.
  4. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I think the 14sf and the rear dana 60 are about the same in strenght except that the 14 is an semi floater. /forums/images/graemlins/dunno.gif
    could be wrong though.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd take the 14 bolt FF just becouse they are cheap and pleantifull.
  6. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    better gear choices, more lockers(ARB), and i think a little better ground clearance, not sure tho
  7. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    If you are running a small tire or a light buggy the 60 is smaller, lighter, has more gear choices (that doesn't realy matter for a small tire though), more locker choices (an ARB would be great on a DD), and is about as cheep as the 14.
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The 14 bolt has much stronger axle shafts. Dana 60 30 spline FF shafts are about equivalent to 10 bolt or 12 bolt shafts. Unless you need low gears (lower than 5.13s), go with a 14 bolt.
  9. xblshortcut
    xblshortcut Registered Member
    Jan 12, 2004
    9
    Georgia
    Just for the record ARB is in the process of making an ARB for the 14 FF. I dont' remember the part number but I emailed ARB and they replied with a part number. The 14 bolt ARB is supposed to be available by the end of the year or so.
    I am just going to run a detroit, and get the ARB for the 60 front.
    Joe Leeper
    '75 CK5 project /forums/images/graemlins/k5.gif
  10. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    They've been saying that for at least four years.
