14bolt ff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blaz90in, May 5, 2003.
  1. blaz90in
    blaz90in Registered Member
    Jan 9, 2003
    58
    Michigan
    i was wondering...i plan on swapping in a 14ff,when i do this swap will i need a new rear shaft? are just a new u-joint?Btw,i have a 90 K5
    TIA,
    ERic
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Kinda depends I guess. Does your truck have any sort of suspension lift out back (blocks or springs)? If it does, you'll be fine and just need the conversion joint Napa #447. If your truck is stock, you may need a slightly shorter shaft, but probably not - the length of the 14 bolt and 10 from axle centerline to yoke is VERY close to being the same.
  3. blaz90in
    Jan 9, 2003
    58
    Michigan
    well on order i have a 4"rough country all spring kit..i plan on running 35's,4.56,10/14ff im hopeing ill be ok with the swap.
    ERic
  4. heavy4x4
    Aug 28, 2002
    3,270
    You'll be fine - sounds like a good setup. /forums/images/graemlins/thumb.gif
  5. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I have 4" rough country with 14ff and d44
    I used the same shaft in back with the conversion u-joint
    Made a new front shaft a little longer after the stock one pulled apart
