14bolt gearing
Discussion in 'The Garage' started by Mike B., Dec 17, 2003.
  1. Mike B.
    Mike B. Registered Member
    Nov 14, 2001
    11
    Raleigh, NC
    i was told the other day that the highest gears a FF14bolt are 5.13. but i cannot find any, i think i found one set on macromotive.com but thats it. i was hoping that yall could offer me with some more places that sells them, or if 4.88 is the highest they can really hold. Thanks!
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    5.13 is the lowest that they can go, however, I don't know where to find any. Randy's ring and pinion might have them.
    -Andrew /forums/images/graemlins/usaflag.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    5:13's are the LOWEST gears I know of for a 14 bolt.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Lowest is 5.13:1 and they are not common. Call around, you'll find them at one or the other of the on-line gear houses (Drivetrain Direct, Randy's, etc.) Be careful with Randy's, he's gotten allot of bad press lately for substandard "Yukon" gears (whatever is cheapest this month apparently).
    When you do find them, take note if they are “thick” or standard gears. Standard 5.13s are almost non-existant. They fit the 4.56 and lower carrier such as that found in CUCV axles (like mine). More common is the “thick” gear made for the 4.10 and down carrier which is also much more common.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Lowest is the term you mean. Highest is the term for "numerically" phrased. And yes, 5.13 is the lowest for the 14FF offered. /forums/images/graemlins/wink.gif
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    West Coast Differentials has 5.13s
  7. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    5.13 is also the ratio that GM put into the eaton axles only with the R05 dually rear conversion RPO, this axle existed 1972 back to 1947, it also came with cab roof marker lamps and in 68-up with lighted side reflectors, normally they were just reflectors in 68 without dually R05 RPO, and some 69's also
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I may have found a 14BFF with factory 5.14's in it at a local wrecking yard for hi pinion. I ran across it when I picked up my current 14BFF and I wasn't interested in it because it was too low for me. I hope I can find it again, for Hi pinion's sake.
  10. Mike B.
    Nov 14, 2001
    11
    Raleigh, NC
    thanks a bunch for the help guys!
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You may be correct. The C3500HD trucks came with 5.13 available in them in the 88-98 bodystyle (15,000 lb GVWR).
  12. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Well I found the 14FF I was looking for but when I poped the cover it was 4.10 open, just a good example how important it is to always check the gears. /forums/images/graemlins/frown.gif
  13. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    theres a lot of realy good wrecking yards here in sac.if one of you guys had some #s you could give us for the 14 bolt that would be a great help!!!(the one with 514s /forums/images/graemlins/thumb.gif
  14. hi pinion
    Sep 25, 2003
    5,354
    GOOD luck mike!!!!!!! /forums/images/graemlins/grin.gif
  15. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I am sure you could call RanchoChevy and they can find what you want. I was there a few weeks ago to buy springs plates for my 14Bff. They will probably be on the expensive side though.
    www.ranchochevy.com
