14bolt Gov-bomb
Discussion in 'The Garage' started by DEMON44, Feb 12, 2006.
  1. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    What are the symptoms of a gov-lock starting to pack it in? I was "blessed" with one in my crew cab, this is the only govlock I've ever had.
    The other day the started a nasty series of bangs when turning, only when turning. Pulled the cover, dumped the oil, which was of a dark nasty thickness. No pieces came out, there was some good sludge on the magnet. New 80-90 into it, closed it up. test driveing for about 45min. Showed some improvement, but it scrubs the tire pretty hard in turns now. Like its lincoln locked. But then for 10min it drives like its open. Then back to scrubing and mild banging.
    Any thoughts or help.
    Thanks.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    weird, either way, i would really start thinkin about replacing it,,,i know mine in my DD doesn't work right, but mine is a worn out clutch problem, it slips most of the time, basically acting like an open diff.
  3. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    Find a spot and start diggin, that gov-lock is no more.
    Weird you brought it up, a buddy and I were just talking about how we never heard of a 14bff gov-bomb going. Sorry to hear it.
    Best option would be to pull an open diff in a j/y and put it in. That way you could throw a detroit on it.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Weld it up solid :thumb:
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    This is a DD, I wasn't leaning to weld. But.....a cheap fix is a good fix :D
  6. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    [​IMG] :weld:
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Hey Man!
    If you want to go to an open carrier, I may have access to a known good 14 bolt with 4.10 gears in it pretty quick. You can have it pretty cheap if I wind up getting it.
  8. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Hey how ya doin? An open would be ideal for me for now. If you get in on that thing let me know, I'd appreciate it. Thanks. Sooner the better too, I don't know how much more life I can squeeze out of this thing before it's final bang :doah:
  9. Russell
    Jun 23, 2000
    7,921
    331
    I'll encourage the guy I want to buy the truck off of, to try and accelerate the deal :)
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have been told that when the 14FF gov-bomb breaks the case is so strong that it does not break like a 10 or 12 bolt so it locks up and acts like a spool hence the reason you are scuffing tires in a corner.
    Ira
  11. dyeager535
    26,975
    My first 10 bolt gov-lock used to stay locked up all the time, never broke anything. Then again, it was a 305 with 3.08's, and 31's.
  12. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    I have a complete diff for you or an open carrier ... what ever want. Check your 4wheeler pm :)
  13. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    That thing is toast. mine died the same way. it did crack the carrier, but you couldn't see the crack throught the oil coating. the brass gears inside blew up and got chewed up by the spiders inside. as larger peices got chewed the spiders pushed away from each other splitting the carrier all the way aroud :eek1: and some how in all of this the whole thing locked up and made like a spool. I could really notice around slow corners (parking lots) as i would try to push the front tires. get a Detroit and open carrier and you WILL love the improvement, the gov-bomb really didn't work all that well off road compared to a locker
  14. Russell
    Jun 23, 2000
    7,921
    331
    Ditto on snoman87's PM -- I may be headed down your way this weekend, and can bring his 14 bolt with, if you help with paying for gas :)
