14bolt rear disc parking brake ??????s
Discussion in 'The Garage' started by rubbinz raczn, Nov 13, 2004.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    i will be doing a rear disc conversion on my 14 bolt ff. what is the best approach to the e-brake,or parking brake issue? i see the cadillac calipers with mech. parking brake. also driveshaft ones. any other options? i know you can use the cheaper 3/4 ton calipers without e-brake. a cable pull setup isn't really what i want to do since i don't have any of the stock e-brake stuff. any ideas thanks! /forums/images/graemlins/thinking.gif
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Those are about your only choices, I am going the caddy caliper route. what t-case do you have?? That will decide if the t-case e brake will even work for you. /forums/images/graemlins/waytogo.gif
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    wheel chocks...that's about your only other option, unless you wanna design some one-off setup like i'm gonna do.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There's one more option.
    Leave the drums.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    but thats no fun /forums/images/graemlins/thumb.gif
  6. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    [/ QUOTE ] /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif i f%%cked up and went with a rebuilt np208 for the th400 i had instead of coughing up for a doubler that i wanted! so i think the tcase brake wont work? nobody makes a linelock type unit suitable for e-brake use? /forums/images/graemlins/dunno.gif
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    the line lock works with you hydralic braking system so there would be not point for it if your brakes failed.
  8. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    Leave the drums.
    [/ QUOTE ] no parking brake on those just cables not hooked up! /forums/images/graemlins/whistling.gif
  9. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
