14bolt rears, whats the difference?
Discussion in 'The Garage' started by jimmyjack, Sep 29, 2002.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I bought a 14 bolt ff, I think. I was under the impression the axle had splines on both ends. Mine doesn't, but it does have to be unbolted from the hub, is it a semi or full floater? I looked at the axle chart and mine is bigger of the two.
  2. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    You should have the full floater version of the 14 bolt. As for the axles being splined on both ends, I don't think the 14 bolt ever came like that. Axles like that come in trucks like the GM 3500HD with a 10 lug D80 rear.
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    It was just an assumption on my part. I've never seen one up close and personal. How do I get to the spiders and stuff? It's not like a 10 bolt carrier. /forums/images/icons/shocked.gif
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i think to get to the spiders you have to pull out the carrier and then pull off the ring gear and the carrier will then seperate in two pieces with the spider in the middle.
  5. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    Chulisohombre is correct, the carrier is like a clam shell with the 2 halves held together by the ring gear bolts. To remove the carrier: you will see an adjuster with holes outboard of each carrier bearing, mark their current position with relation to the housing and remove the small locks. Now, you can use a small phillips screw driver in the holes to rotate the adjusters and loosen the carrier - now it's ready to remove. After reinstalling, screw the adjusters back to their original position and reinstall the locks.
