14bolt ?s
Discussion in 'The Garage' started by big dan, Feb 8, 2006.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I will soon be swapping in my 14b rear and will probly end up doing it myself. because of this i want to remove as much weight as possible to make it a little easier. i plan on removing the axles hubs and drums. my question is if i remove the pinion support will i have to adjust or reset up my gears when i put it back or can i just pull it and replace it when im done?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    u can remove it & put it back in, just be sure to keep up w/ the shims, & put them back.
  3. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    ok thanks
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    why not just put some small tires on it and roll it under the truck?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    way easier than moving a bare housing into there.
  6. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    duh, now i feel somewhat retarded for not thinking of that.:o thanks anyway guys
  7. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    The 14 bolt with the larger size drums will roll on the drums alone. I had one out of a 1983 K30 pickup that would do it.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Small tires are great for swapping axles and also to drive it in the garage for repairs/upgrades. I saved these from my mom's car. They fit a 16" wheel and measure only 26" tall aired up. You can run them flat to lower the truck another couple inches.
