14BOLT SF information?
Discussion in 'The Garage' started by CHEVY 4WD, Aug 15, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Im trying to learn about them I need a 6LUG one and just wonding what years will dirrectly bolt into our style trucks and have the same width,(I would like to know the other widths also) Did any of them come with disks and are there disk kits out there? anyother information would really help me too. BTW I DID SEARCH /forums/images/graemlins/grin.gif
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I did a Search too /forums/images/graemlins/wink.gif
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I can't tell you exact info...but they are out there. Look for a later model light duty 3/4 ton. The really new ones have discs. Also the Z71s with the towing package came with 6lug SF14s. I think the 6 lug SF14 is a good upgrade...if you are gonna go 8lug don't waste your time.
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I looked into this quite a bit before I just gave up and got a FF. I belive it's 88-98 (not sure after that) light duty 3/4 tons (6-lug) and some Z-71's. I have seen the Z-71's with 10b's. My buddy has a 91 2500 that is 6 lug and it has a 14bsf. All I know is they are a lot harder to find. Have you tried any of the junkyard search engine's? I like junkyarddog.
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    The only way you are going get a BOLT IN one is get an 8 lug and run adaptors or swap to 6 lug shafts. All the 6 lug axles discussed above are not a bolt in.
  6. Ruff_ryda_420
    Ruff_ryda_420 Registered Member
    May 22, 2003
    19
    alberta
    okay, is it possible to run a 15" wheel on a 14bsf? i would go with 16s but i just brought home some 38" swampers.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Only EXTENDED CAB Z71s with the heavy duty suspension get a 14 bolt semi floater just as a simple correction.
    15" 8 lug wheels will fit on any rear axle that Chevy has ever used.
