14bolt swap driveline?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sasquatchhunter, Jul 17, 2003.
  1. sasquatchhunter
    sasquatchhunter Newbie
    Jul 17, 2003
    I have a 1976 k5 with a 12 bolt rear end and I was going to switch it over to a 14 bolt. I was wondering if I could get a way with not replacing the drive line right now? Is it a must or can a drive it around with the old 12 bolt one? My friend said I would but he wasn't totally sure
    /forums/images/graemlins/k5.gif
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The old drive line will work fine, just but a conversion ujoint. You can get them at pretty much any auto parts place. Do a search - the part number has been put up many times in the forums - I just don't have it.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You need Napa PN 348 it's a 1310-1350 combo joint used when swappin' in a 14 for 12...
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    12B to 14BFF conversion U-joint....Napa P/N 348 /forums/images/graemlins/thumb.gif
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Just keep in mind that the 14b pinion sticks forward further. This will make the driveshaft seem shorter. If you are lifted with a stock driveshaft, this is actually a good thing.
  6. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Actually, it doesnt. They are the same. At least on my 14B and 12B. /forums/images/graemlins/smile.gif
    Mike
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    yes, it stick out much farther, which explains my driveshaft having to be shortened 3" during the swap. idk what you are talking about thumper, sorry. i had a 12b too.
  8. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    There must be a definite answer for this somwhere as to pinion length differences. But going from a '91 10 bolt to a '73 14 bolt, the pinion lenghts were dead on. No driveshaft mods for me. /forums/images/graemlins/thinking.gif
