14bolt thick gear torque specs needed...........
Discussion in 'The Garage' started by jjlaughner, Jul 3, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OK, I got some thread lock, I got the govloc welded up and I'm getting ready to mount up the ring gear. What do I torque the ring gear bolts too? Is there a different (longer) set of bolts for the thick gears? Otherwise I'm going to use the bolts that come out.
    /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/waytogo.gif
  2. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    80ft lbs, tighten like an 8 lug wheel. i think the bolts shouldn't need to be any longer, seeing as "thick gears" are thicker the other way, as in the have a smaller hole in them, to compensate for the smaller diff case, so the bolts won't be different. make sure you got your lock washers on there.
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/waytogo.gif cool thanks
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    120 LbFt from Randy's /forums/images/graemlins/waytogo.gif
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/yikes.gif
    Good thing I'm lazy and didn't bother putting the ring gear back on today! /forums/images/graemlins/ignore.gif
