14bolt to good to be true?
Discussion in 'The Garage' started by IDGMC, Dec 12, 2005.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    I posted an ad in the local sooper ad for a set of gm axles with 3.73 or lower gears and got a response from a rod and custom shop who has a front and rear 3/4ton (dana44/14bolt) with 4.09/4.10 gears. He says he's hurtin for money and would sell me both for $150.00
    So do you think they are junk? or a steal? What is the spacing on the rear leafs need to be to match up to my blazer?
  2. Bluekrow
    Bluekrow Registered Member
    Aug 16, 2005
    33
    Cedar, MI
    It should be a direct bolt in if the axles came out out of a K20 pickup. The axles that came out of a van are a different spring perch width. If you get them you might want to check/change the Bearings and seals before you install them. Goodluck
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    definately not too good to be true. 14bs go for cheap as it is, as do 44s/front 10bs. It is a really good deal for both of them but i wouldn't go so far as to say too good to be true. Might as well look into it, could come out with some nice 3/4 ton axles for cheap.
  4. IDGMC
    Feb 18, 2000
    150
    Idaho
    Thanks, I kind of know the guy indirectly.....I can run 15" tires on the 14 bolt can't I? Will the 4.10 with 33's and a th700r4 be wound up to much?
  5. redneckdude
    Feb 21, 2004
    578
    Augusta, GA
    I think you can get away with it in the rear, but in the front, depending on BS, you might have to grind the calipers some. I have 8 lug outers in the front and i don't see how 15s would fit if they have more than 3" BS (my current rims have 2 3/4" so it BARELY works). You would actually have great overall gearing. Remember, the 700 has OD which will bring those 4.10s back down to where your gearing needs to be IMO.
  6. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    Yes 15's can fit on the 14ff and no the 4.10's wont wind up the tranny to much. It should be perfect for 33's. I run 5.13's and 35's and can still cruise down the freeway
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Also may want ot check that the 14bolt is a FF os SF.... Some light duty 3/4's got the SF... Not sure if they went back as far as the trucks with D44's though...
    But either way, sounds like a good deal!
  8. IDGMC
    Feb 18, 2000
    150
    Idaho
    Thanks guys...i'll call the guy tonight and get um!
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I paid $150 for a '77 K20 with a D44/14BFF combo with 4:10's. There was no engine, tranny, t-case or d-shafts. Your deal sounds about right.:D
  10. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    4.10's and 700r4
    I run 4.56's with a 700r4 and 33's and love it. I can cruise down the highway at 75 @ about 2500rpm's. Plus I've got plenty of torque for wheelin'. With 4.10's, your rpm's will be a little lower, but you should still have plenty of torque for wheelin'. :D Rick
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Good price and good setup for your truck.
