14Bolt???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OLDSTEEL, Apr 8, 2000.
  1. OLDSTEEL
    OLDSTEEL 1/2 ton status
    Mar 11, 2000
    107
    SANDIEGO CA
    I found a 14 boltFF with 4.10 gears and about 100K miles on it. The guy from the junk yard said it was from an 83 Burb 2x4 and that it would not fit under my 74 K5. Does anyone know if this is true?
    74 K5
    Leave it like you found it, or better!
  2. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Check the Spring pads and the shock mounts if they are the same it will fit
    If not you could have them rewelded
    350 Vortec TPI D60 14Bolt 4"lift 35 BFG A/T
