14BoltFF 1 ton vs. 3/4 ton
Discussion in 'The Garage' started by az88k5, Dec 12, 2005.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I am curious what is the difference between a 1 ton and a 3/4 ton 14Bolt FF other than spring perches being different. Correct me if I am wrong but the spring perches on a 3/4 ton will match up to a Blazer but not on the 1 ton. Is there anything else that is different between the two? Please let me know. Thanks
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
  3. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    So the only difference between 3/4 and 1 ton 14bff is the spring perches and shock mounts. The rest of the axle is identical? The 3/4 ton 14bff is a direct swap for a K5 Blazer and the 1 ton will need to have perches and shock mounts moved? Please let me know if I am correct.
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    yup
