14bsf - 6 lug and disk brakes?
Discussion in 'The Garage' started by Chevy305, Dec 29, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Ok I got new 6 lug wheels for xmas and I want to keep them. But at the same time I need to upgrade my rear end from the 10bolt. I have done some research on the 14bsf and I found that 81-87 it was available only in 8 lug but everything will bolt up under my 85 K10. Then 88-98 it was available as 6 or 8 lug but the spring perches will need to be moved. Through my research and searching on this site I have found a bunch of bits and pieces of info that I would like to put together.
    I believe the 14bsf never came from the factory as 6 lug and disk brakes.
    I am looking for a 4.10 ratio which I believe is pretty common. I would prefer if I could find (or convert) a 14bsf to 6 lug. So I do know the 8 and 6 lug axel shafts are interchangable, but then I'd run into problems with brakes. I know there are kits to convert to disk brakes, but there are all different types of spacing and axel shaft lengths which have me confused a little.
    Could anyone give me their 2 cents on what I need to convert a 8 lug 14bsf to 6 lug and then maybe even convert that to disk brakes? Or if not disk brakes, are the 6 and 8 lug drums directly interchangable? Also exactly what is interchangeable from the 81-87 version and the 88-98 version? :confused:
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    If you weant to go 6 lug and disc brakes it would be pretty easy.
    Black widow makes a 6 lug conversion kit with disc brakes (or if you find a 6 lug axle, they have just the disc brake kit)
    As for 88 and up and 87and down they are the same axle, just differant perches/ shock mounts. Some may be differant widths though...
    But if your going to go to 4.10's that means youll have to re gear the front or get a matched set. Your best bet is find a set of 3/4 ton axles , rebuild them, get 8 lug rims. It will be much easier/ less hassle and most likely cheaper in the end.
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Even cheaper and easier: get spacers/adaptors made that bolt on the stock 8 luggers and converts it to 6 lugs.
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
  6. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Sorry but 8 to 6 lug adapters don't exist. You can't do it because some of the lugs run into eachother.
    Also I already have 4.10s in my 10bolts front and rear. I learned that 3/4ton axels would have been a much better route rather than rebuilding my 10bolts. Oh well, you live and learn. :rolleyes:
  7. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Thanks for the links
    I guess the search that I did, somehow didn't come up with those threads.
    Anyway, today I went to the local scapyard and I found 5-6 14bsf. All 8 lug. 2 were from the 81-87 style pickup and 2 were from newer 88+ style, and the others were in vans.
    After reading through everything, i think I will go for the 81-87 8 lug rear. one was from a 4wd and the other was from a 2wd. I will go for the 4wd one because it is supposed to be the wider of the 2. So the rear will be $100. I just need to verify the ratio is 4.10. How do I figure that out through the VIN or some other number like that?
    Also I looked it up and a 6 lug/disk brake conversion will be $395 from Blackwidow performance. The only other parts I would need are the calipers and brake hoses. Since I have the 465 and MA State insepction needs to have a working e-brake, so Caddy calipers here I come. I looked them up and Autozone says a pair of loaded Caddy calipers are $150. But I have heard some bad things about autozone crap so does anyone have the GM part # for loaded Caddy calipers?
    Also does the e-brake cable hook up to the caddy calipers just as it does to my 10bolt drums? Or will I need some special cable?
    Also with the D44 rotors and the Caddy calipers, will I have any trouble fitting my new 15" wheels on there?
    Also I always thought that the rotor had to be on the outside of the axelshaft, but I read somewhere that you can mount them on the inside of the axel shaft. How does that work? Are there sepcial wheel studs for that? What are the advantages? Also wouldn't that need a different spacer on the caliper bracket?
  8. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    You can check the RPO codes in teh dash to check factory ratio, but no saying they havent' been changed.
  9. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    On the 88-up 9.5's i've worked on, the ratio is written on the ring gear, so all you have to do is pull to cover. Not sure if it's on the earlier ring gears or not. On a older truck, I'd say it's 50-50 chance it's 4.10's or 3.73's. RPO code is the easiest way if it's stock and readable.
  10. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Where do I find the RPO code, and how do I tell from it what ratio the rear end is?
  11. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I'm not surprised that you can't find any 6 lug 14bsf's. They weren't as common as the 8 lug units, and most are pulled by the recyclers before the vehicle ends up in a pull-it-yourself yard. At least, that's the case out here... :(
    In the end, you may be money ahead to simply pony up for a 6-lug from a recycler who has already pulled it. You can probably find one with 4.10's, and it should have all the brakes, etc. Basically, you can just move the perches and throw it in. It would probably much cheaper than swapping ahfts, brakes, etc.
  12. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    So does anyone have the GM part# for caddy calipers? Or could suggest a good parts store to get them from?
  13. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Caddy Caliper help PLEASE!!
    Ok just found out that GM has discontinued Caddy Calipers and parts that will go with them. But Autozone still carries them, so if i were to get the Calipers from Autozone, what else would I need to connect the e-brake cable to them? I have no idea about rear disk brakes someone help me out!!!
    I have searched and everything, but all I get is bits and pieces, no one has a complete thread on everything needed to run Caddy calipers in order to retain the e-brake.
    EDIT: Ok found a thread to answer my questions http://coloradok5.com/forums/showthread.php?t=177560
    search button = :bow:
  14. dyeager535
    26,979
    Pull the cover if you are buying one. Do NOT buy an axle without doing this. Make sure you get what you want, and it's not broken. Both gov-lock, if you want it, and that the pinion shaft lock "bolt" isn't sheared off.
    Not to mention, you know what ratio you'll have for sure.
    RPO's are a decent way to start, but don't stop there, just use it as a way to narrow your search down quickly.
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Chevy, you have a pm :whistle:
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    easiest way to ID... count the ring gear teeth, and count the pinion gear teeth. divide the ring by the pinion. should be 41:10 for a 4.10, and may be marked on the side of the ring gear too.
    also, what brand are the AutoZone Caddy calipers? what kind of warranty?
    another thing you have to take into consideration is the core charge...
