14bsf 8 to 6 lug?
Discussion in 'The Garage' started by jk3078, Dec 19, 2005.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I did the search and still????
    What all needs to be swapped besides axles? Drums? Brakes? The 14bsf is already welded and i just put new seals and brakes on it. I think this axle with six lugs under the sub-buggy would be be able to handle the 36" Irocks much better than the ten bolt!:burb: :hack: :grind: :weld: :thumb:
  2. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    Just take out the axle shafts, remove the wheels studs and weld the holes, redrill the 6 lug pattern, insert the studs. Redrill the drums to 6 lug, assemble. Finished. :) Easy peasy!!
    If you don't have the proper tools let a workshop do the drilling for you, then you know that everything will be centered properly. That can't be expensive.
  3. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Make sure your wheels will fit over the center of the axle. I know that stock steel wheels won't.
  4. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Never looked at it that way! Sweet! And yes much cheaper than buying all the parts I'm shure! I know an old boy here in town that works cheap and is reliable. God damn I love this web site its savin me money left and right!:bow:
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Not so easy;
    1. The stud hole patterns do not allow for it in the drum. You will have 2 holes that do not fit correctly.
    2. Welding that much on the axle flange will warp it unless you are VERY careful.
    3. Both of those combined make it difficult to line everything up for the brakes to work correctly.
    4. You will have to machine either your wheels (center hole) or your axle nubs to fit.
    I have tried this conversion on MANY different 14BSF axles. I found the easiest/fastest way (also most cost effective) is to convert it with some aftermarket shafts and a disc conversion.
    Been there done that, learned the hard way :doah:
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Damn, its too bad you didnt post this last week. I just threw out some SF 6 lug shafts on friday.
  7. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Any one else got 2 cents?
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i got a question bout ur k5...why are u running a 14bsf with a 60 in front? i guess you jus love semi-float :-)
  9. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    I got the 14bsf with a 3/4 ton 44 front for $30! The 14bsf is a good axle for 36''-37'' or smaller tires. the pros of this axle are much better strengh than a 10b or 12b, better ground clearence and lighter than a 60 or 14bff , no need to tear down the carrier to weld it and the brakes are easy to service. The only con is the c-clip axles but I have had no problems with this axle after 2 years of hard use under a 5700# pound truck. I will be swapping in a shaved 14bff with 5.13s and a spool or welded into the k5 soon but only to pave the way for 40'' or bigger tires down the road. This axle will be going under the sub-buggy and a six lug conversion would be lighter and cooler than swapping the front over to eight lugs. I also have several sets of six lug wheels and no wide 8 lug wheels. So how did you all do your conversions? drill or swap?
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ok for $30 i guess its ok haha.
  11. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    POORBOYS OFFROAD!!!!!!
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    why not jus keep it 8lug for now? it will be alot cheaper that way. then once u find 6lug shafts and such buy them, over time you will have everything u need, and cheap.
  13. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    I have all the parts to swap the 10b front over to eight lug but I dont have wide eight lug rims and new thats about $350. I have 3 sets of cool 6 lug wheels, so I'm stuck inthe middle cost wise plus the eight lug setup would ad another 100# or so to the rig. If re-drilling the axles wont work than I prob. will do like you said and wait for a deal
  14. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Anyone know of a source for the parts to do this conversion on the cheap?
