14bsf yoke question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, May 24, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    The idiots that torched the bolts that hold the yoke straps on left messed up stuck bolts in the yoke of my 14bsf. I'm thinking of just replacing the whole yoke. Are there any particular part numbers I need to know and how hard is it to replace a yoke?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I went to GM to get mine. Cost me $53. Pretty easy to replace as long as you have a puller to remove the old one. Replace the pinion seal while you're at it. Don't over tighten the pinion nut or you'll kill the pinion bearing. Be sure to use red lock tite.
