14FF and Dana 44 From a 78 GM 4x4 pick up.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Aug 19, 2002.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    Will a 14ff and a dana 44 from a 78 pick up bolt right up to my 90 jimmy?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    yes /forums/images/icons/grin.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    In '78 the front axle is more likely to be a 10-bolt. But yeah, they'll bolt right into your current ride. /forums/images/icons/cool.gif
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    GM was still using the Dana 44 in '78. I have a set of 3/4 ton axles out of a '79 and the front is a D44.
    Mike
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It just depends on the ratio and such. They started using the 10-bolt up front around mid-77. Once a particular configuration of the Dana 44 was used up, the trucks got 10-bolts. It may have taken longer for them to use up the 44's in the 3/4-ton line, as not as many of them are sold.
  6. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i just got my axles installed from a 78 3/4 ton. it has a d44 and 14bff<(duh) but they bolted right up...just a lil bit heavier /forums/images/icons/smirk.gif
    NITRO
