14FF and stock mstrcyl with disc conv
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spoolnaround, Jul 28, 2002.
  1. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    How can a stock master cylinder work with a 14ff disc brake conv? The resivour for the rear brakes is so small how can that be enough for the bigger pistons in the calipers? Are you guys using a different master cylinder? /forums/images/icons/confused.gif It just doesnt seem it would work.
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    im using factory everything---master, proportioning valve, etc and the truck stops on a dime--
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Same here except that my truck will stop on a dime and give you eleven cents change. /forums/images/icons/laugh.gif
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    The extra fluid capacity is needed when the pads wear down and the caliper pistons are extended out more. If you keep an eye on your brake fluid and add more as the pads wear (then suck it out when you put new pads in), every thing's cool. /forums/images/icons/cool.gif
    That being said, I've found a late model master cylinder (four wheel disc) that I'm saving for my Jimmy.
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I went to a 1 ton MC. Everyone says you dont need to, but I like the extra capacity the larger MC holds and it has a bigger bore to push more fluid.
  6. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Great info as always guys, thanks.
  7. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Outlaw, when you went to the 1 ton, did u have to change to booster as well?
    Toying with doing similar on my 91.. but not sure how it'll effect the rear anti-lock & booster...?
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I put on the 1-ton master when I did the Disc conversion and kept the same booster. Don't know how it would act with your anti-lock.
  9. outlaw612
    Feb 11, 2001
    2,342
    Nope, just installed the 1 ton MC into my 1/2 ton booster.
  10. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I have a 85 K5. So what year 1 ton master cyl. would I ask for and does it have the metal style cap with the top latch or just the normal push down latch? /forums/images/icons/confused.gif
  11. outlaw612
    Feb 11, 2001
    2,342
    I dont remember what year I got for sure. It was an early 80's. Just make sure its the Non-Hydro MC.
