14ff Axle bolts loose. Is this normal? I tightened but...
Discussion in 'The Garage' started by jakeslim, Apr 7, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    I changed the bearings not to long ago and put back together. I noticed fluid that had "spun" all over my rear rims. I grabbed a wrenched and found that both rear axles were loose. All the bolts on both sides....is this normal? I am sure I tightened. Even if it was error, both sides would be hard to believe. /forums/images/graemlins/dunno.gif
    Anything I should be looking for?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I would guess you just undertorqued them. Torque spec on those is 115 ft-lbs.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Just tighten them and watch them next trip. Ive never heard of them loosing, in fact the bolts have a knurled head so they should stay tight.
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Loc-Tite /forums/images/graemlins/waytogo.gif
    Chris
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    mine come loose on occasion, just make sure they are tight, and also make sure you have the right gasket.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I use my tire iron/4-way wrench to tighten mine, i just tighten them as i do with the lug nuts. Never had any come loose on me.
