14FF axle question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by gbfan, Aug 28, 2004.
  1. gbfan
    gbfan Registered Member
    Oct 24, 2003
    18
    SCarolina
    Did a search but found nothing. 72 blazer swapped in a 14 bolt out of a 76 C20. had to weld new spring perches on so I angled the pinion up for pinion angle. Now it seems the gear oil is leaking into the axle tubes and into the hubs. Is there an axle seal in there? or because I angled the pinion up I am over servicing the rear causing it to run into the axle tubes?
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The wheel bearings on a 14 bolt (and most other full floating rears) are lubed by the gear oil. It is supposed to be in the hubs. You do not need to grease the wheel bearings.
  3. gbfan
    Oct 24, 2003
    18
    SCarolina
    That is good info I did not know that. I have a disc brake set up. If it is leaking out onto the rotor I should change that hub seal?
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Well, you do need to make sure they are lubed upon assembly. Either by packing them with grease or by shooting some oil into the hubs on assembly.
  5. kennyw
    Jun 9, 2002
    13,224
    94
    I'd say it sounds like the hub seal if it is leaking on the inner side or the axle gasket if it is leaking on the outside. /forums/images/graemlins/thumb.gif
