14ff backlash and d44 torque spec
Discussion in 'The Garage' started by Redfrog, Oct 2, 2004.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    since the search is not working and I am a moron who go in a hurry, I did not check the backlash before I pulled the carrier, I did how ever count the # of turns on the adjuster nuts, so now that I am ready to put it back together I can't get the adjuster nuts spun back to where they were, they are both a turn short if I get one side to where it was the pinion gets REAL hard to turn. Hope that made since, does anyone have the spec for backlash handy? it is for used bearings and gears if that makes a difference.
    also Does anyone have the torque for the yoke on a D44hd?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Preferred Backlash .005-.008" Min-max Backlash .003-.012"
    Drive Pinion Nut D44 255 ft/lbs
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Is it a used gearset?
  4. Redfrog
    May 4, 2001
    753
    IL
    yes it is a used set,
    How is a person to reach 255 ft/lbs with out the use of a large torque wrench
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    a lot of gear sets have the optimum backlash engraved on the OD of the ring gear too. My Precision gears for my 14bff called for .008" of BL when I set them up. /forums/images/graemlins/thumb.gif
    Chris
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    and rent/borrow a good 1/2" torque wrench if you don't have one for the pinion nut
    Chris
  7. Redfrog
    May 4, 2001
    753
    IL
    Thanks guys, I guess I have a excuse to go buy a bigger torque wrench /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If its used you dont want to set the backlash at .008, too tight, it might make noise.
    I would set at .015 or so and check the pattern, and just go from there.
