14ff brake ?'s
Discussion in 'The Garage' started by dubl_t, Jan 5, 2003.
  1. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    14ff brake ?\'s
    Coming back from Wyoming, my seal went out and got diff fluid all overthe brakes. Now, the 6 prong socket I got from Napa dosn't fit. Does anybody have a part #? for a good one? And, can I clean up the shoes since they were fairly new? Also, it looks like an "oil slinger" that the seal rides on is torn, any tricks o replacement? Thanks for the speedy responses
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Re: 14ff brake ?\'s
    I had to buy my hub socket at a mom and pop part store - autozone, o-reilly, etc. did not have it.
    I think the shoes absorb oil and will need to be replaced - not 100% certain though.
    What slinger are you talking about? I replaced the hub seals on my 14 bolt FF and I didn't have any slingers.
    -- Mike
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Re: 14ff brake ?\'s
    roger on the shoes they are shot. they will work but theyll smell, smoke, pull, and stoppy crappily.
    nathan
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    Re: 14ff brake ?\'s
    So what are the prices on 14 bolt shoes, drums cost also if you know the cost of new seals and bearings getting a 14 bolt ff tomarrow and want to rebuild it first. Also I need a carrier bearing how much are those and will I have to go store hopping to find all these parts? /forums/images/graemlins/1zhelp.gif
    not trying to hyjack your thread just have related questions
    Thanks Shawn
  5. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Re: 14ff brake ?\'s
    If your spindle nut are 6 lug, you might just round off the lugs on the socket, it's what I had to do.
    Brett /forums/images/graemlins/burb.gif
  6. dubl_t
    Jun 8, 2002
    141
    Oregon
    Re: 14ff brake ?\'s
    Supersize75: Can't help ya w/actual $#, but parts are relatively more expensive. But for the application they last longer and are more durable. I canusually find everything at Napa. Some parts I buy at "discount" houses, but with parts like bearings, you get what you pay for.
  7. dubl_t
    Jun 8, 2002
    141
    Oregon
    Re: 14ff brake ?\'s
    TX & 69: Yea, that's wat I was afraid of regarding the shoes, but I'm suprised (?) you ddn't havea slinger that the seal rides on. Maybe it's not necessary?
  8. dubl_t
    Jun 8, 2002
    141
    Oregon
    Re: 14ff brake ?\'s
    77fixer: It looks like my socket wll work if I "modify" it, I was jus wondering if anybody else had to. Now, should I pack the bearings with grease?
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Re: 14ff brake ?\'s
    The hub seal is a few dollars. Shoes are inexpensive.
    I think inner and outer bearings w/ races will cost you about $90 for both sides.
    How do you know the carrier bearing is shot? I doubt you can just buy it anywhere. I got all my differential bearings from Randy's Ring and Pinion, in a kit.
    You can get everything else at Autozone.
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 14ff brake ?\'s
    <font color="green"> I had to modify my 14b tool as well. Just knocked the edges off the inside corners of each prong and it fit like a glove. </font color>
  11. supersize75
    Sep 27, 2002
    2,638
    Re: 14ff brake ?\'s
    I think or believe the carrier bearing is shot cause the guy said it was when I bought it he said it made a small noise and yes I inspected the rest for wear.
    Can you put up a pic of your modified tool I have no clue what ya mean. /forums/images/graemlins/grin.gif
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 14ff brake ?\'s
    <font color="green"> OK, I;m not gonna touch that one with a 10 foot pole, but I'm sure someone will come in and hijack this thread based on that comment...
    If you actually want a pic of the modified 14 bolt tool then I can go take one right now, just let me know. /forums/images/graemlins/thumb.gif</font color>
  13. supersize75
    Sep 27, 2002
    2,638
    Re: 14ff brake ?\'s
    me so sorry /forums/images/graemlins/grin.gif
