14ff build 85% complete.
Discussion in 'The Garage' started by ryan22re, Aug 27, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    My 14 ff is almost done. Just need to finish the brake lines/hoses and replace the perches. Need some advice on the perches though. When I installed the axle in my old blazer, I was in a rush and used some el cheapo spring perches. Guy didn't do too great of a job welding them on, plus they are the un-boxed kind. I have a set of DIY4x spring perches to replace them.
    I'd like to install them now, any ideas on how to set them up without the axle in the truck? Most likely the setup will be a 465/208 with a 4 inch shackle flip on 52's with a 6 inch shackle (nets 5 inches of lift). I was thinking of leveling the pinion and then have them welded up. I can shim it from there. Ideas?
    Heres the completed pics for the (pic) whores. I installed a DIY dif cover, gaurdsman, disc conversion, replaced all the seals and checked all of the bearings. Got some braided stainless hoses for the brakes. 12 inchers from the calipers to the hard lines and then 36 incher to the frame. (will be way long I know, but better safe than sorry.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I would start by measuring the angle of the existing perches then weld the new ones on about 6* different with the pinion pointing more upward. This should get you reatively close then you could shim from there. If you're going to use a CV rear shaft just remember that the pinion needs to point about 2* down from inline with the driveshaft. That's my $.02
  3. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Anybody know what the spring spacing is on 1/2t trucks? Exact measurements?
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    42 1/2"
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    42 1/2" is confirmed for a 1/2 and 3/4 ton axle.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    It's hard to get the pinion angle just right outside the truck. You can measure the existing angle and adjust but still not as safe as waiting till its in place.
    Looking sweet!
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Thanks to you Kert!
    All I need now is a truss and a Raptor.....:wink1:
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    mmmmmmm Razorback.... :)
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I've got a matching one for the front, hope I can find the cash to send it back to Kert and have a hydro mount added.
  10. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Not bashing Kert's products AT ALL! but make sure there is enough gusseting. I had him whip out a hydro mount that I needed in a big hurry and built to my specs and it's got a slight bend in it. If you're getting a hydro mount that's welded to the cover instead of a piece beside the cover, totally disregard this statement, Jose is getting the best of me tonight. :haha:
  11. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    It'd be the mount that Kert sells that goes with the razorback D60 cover.
    It's really bad when you can't afford to send him a diff cover to have a tab welded on it.....:doah:
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Ya know, I feel a little bad making this offer publicly, but if you want it...I'll pick up the tab. You've given me enough awesome advice, not to mention the TH400/241 adapter that I really do owe it to you.
  13. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    OK, but will you still love me in the morning?
    :haha: :haha: :haha:
  14. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    this is going south real quick..
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Pay the shipping and I'll pick up the tabs and welding. Yes, I'll still love you in the morning.
    Also, Black Medallion in a Tequila Sunrise gets me ****ED!
  16. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Deal.
    Crown royal here boyyeeee
  17. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Call Kert tomorrow and tell him what's up. Terry's guy still owes me $280 for my 350 so he can just take it outta Terry's wallet. :haha:
  18. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Roger roger.
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    :haha:
  20. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Downhill fast it is....
    Still waiting for pics of your hootus and a dana 60 beater....
