14FF buildup
Discussion in 'The Garage' started by sandawgk5, May 7, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I just got my housing stripped down today and now I need to clean and paint it. My question is I intend to put disk brakes on this thing and do I need to use the E-brake calipers or can I get by without an E-brake. My eventual goal is to have a T-case E-brake and I dont want to dump the money on caddy calipers if it is not necessary. Also I heard that they dont really work anyhow they just kinda put a "check in the box" so to speak. And if I do need the e-brake calipers does any one know a cheap place to get them with the arms and springs?
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i am using the caddy calipers, and have the e brake wroiking great with the stock lines. no problem at all using it. you do have to rememnber to use it though as it keeps the caddy calipers adjusted. i also went this route because of inspection laws in jersey. i guess its up to prefernece.
    i went to www.car-part.com to get my calepiers. even if you get cheapos and use them as cores, at least youll ge the spring and lever with it.
  3. sandawgk5
    Oct 28, 2003
    6,881
    I checked that site and the cheapest ones were $50 each side. Maybe I am not using the site properly dunno I will keep checking.
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    i got lucky and got them for around 15 bucks a side. when i got them they were in good condition too. i just wanted new ones. keep checking and you should find a deal
  5. sandawgk5
    Oct 28, 2003
    6,881
    Another question as I show my stupidity. It has been awhile since I have bought brake pads. When they are listed as a set, is that 1 side or is it both sides?
  6. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    They should come with 4 pads enough to do 2 calipers..
  7. sandawgk5
    Oct 28, 2003
    6,881
    Thanks. I know its a dumb quetion but I havent done a set of brakes in like 10 years. I have never owned a car long enough to need a brake job.
