14FF Carrier diff?
Discussion in 'The Garage' started by BlitzK5, Oct 9, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Whats is the reason there is two different sizes. Smaller for 4:10 and down and bigger 4:56 and up? Is there a strength difference or something and what would the advantages of going to the bigger be as opposed to the smaller one? You can get any size of gears for both ones right?. Has anyone broke the smaller type of carrier and switched to the larger one?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    There are two different ones because the pinion size changes depending on the ratio. For example, and 3.21 ratio (14 teeth) would have a much larger pinion gear than a 4.56 ratio (9 teeth). Therefore, the ring gear needs to spaced closer or further away from the pinion accordingly to mesh properly.
    Some axle manufacturers choose to keep the ring gears similar thicknesses, and vary the 'offset' on the differential to suit. Other manufacturers just use one differential and vary the thickness of the ring gear depending on the ratio. The aftermarket tries to follow the latter method.
  3. BlitzK5
    Jul 29, 2005
    288
    So I just need to find a company that makes the larger ring and pinion for the smaller carrier. Im looking to get 4.56 or 4.88's Do you know of any?
  4. BlitzK5
    Jul 29, 2005
    288
    So strength factor is not a issue between the carriers then right?
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    Yes, that's what's known as the 'thick' gears. There seems to be plenty of places to get them.
    Not that I'm aware of.
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you have a 4.10 and down carrier you can buy a thick gear if you want 4.56, 4.88, or 5.13's but if you have a 4.56 and up carrier you cannot buy any 4.11, 3.73, 3.24 gears to fit that carrier.
