14FF carrier main cap bolt question, thoughts.
Discussion in 'The Garage' started by rdn2blazer, Dec 30, 2006.
  1. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    so I have read the entire billa vista 14 FF bible and even copied it from Pirate. it says to put NEW bolts in the main caps and lock washers. BUT dont use regular grade bolts or lock washers. the regular G8 washers are not as thick as the OEM ones are and the factory bolts are a special length, 2 3/4 long.
    I understand the bolt length is different overall but as long as the shank length is the same, say if you took a 3 in bolt and machined if to 2 3/4 whats the difference?
    I bought grade 9, F911 bolts that are exactly the same shank length, just 3 in long. I figured I would just machine them to the same lenght as the OEM ones. I went with the stronger G9 just because I dig extra heavy duty :D .
    as far as the washers go, I agree with the article, so I still need to find the extra thick lock washers.
    see any problem with this?
  2. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Sounds good to me. Check into the high alloy loc washer. I believe they are thicker but stronger, longer lasting for sure.
  3. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I don't know about the 14bff. but most GM rears use flanged grade 8 bolts with no washers. A standard grade 8 bolt with a hardened AN or SAE (if it will fit) washer could be substituted. I don't see a problem with re-using the bolts - they aren't stretch-to-yield bolts after all...
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    :haha:
  5. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    what you laughin at!:haha:
  6. rdn2blazer
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    all three 14FF's I have, have non flanged G8 bolts with extra thick split loc washers. these are the factory setup. I agree about reusing the bolts, this is what suprised me in the article saying not to reuse them. I can see replacing the washers. the bolts do have a gouge from the loc washer though.
    I think my G9 bolts cut to proper lenght will work fine with extra thick split loc washers. I even thought about using ARP studs if they make them in that size, but I did not check yet.
  7. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I wouldn't hesitate to reuse the original bolts with hardened washers instead of lock washers. But that's just me :D
  8. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    yep, re-use the originals! if the lock washer still spreads when its taken off, re-use that too..
    whats next-- replace the diff cover bolts too? :)
