14FF Carrier Swap Q's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Texan, Jan 16, 2002.
  1. Texan
    Texan 1/2 ton status
    153
    Leander, TX
    14FF Carrier Swap Q\'s?
    Have a few questions for y'all - want to put a 4.56 14FF in my 89' K5. Is there is a carrier change between 4.10 and 4.56 on the 14FF's? At any rate, I have a 4.56 14FF in my 94' GMC 1 ton and I'm wondering, if I can come up with a 4.10 14FF out of a 3/4 ton to bolt into my 89', can I just swap gears and carriers between the two. The 4.56's are a little steep even with the OD in my stock tire'd GMC. If I can swap like this then does anyone know what's involved in a front gear swap on the newer IFS 4x4's? Any different than a solid axle swap?
    Thanks,
    <font color=orange>STEVE<font color=orange>[​IMG]
    67 Camaro 468
    68 CamaroSS 327
    89 K5 Blazer
    94 GMC K3500 Crew Cab 4x4
    98 Pontiac GTP
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 14FF Carrier Swap Q\'s?
    The carrier split is like you said...4.10 and higher and then 4.56 and lower.
    You can also get those 'extra-thick' gears to use on the 4.10 and higher carrier.
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. Texan
    153
    Leander, TX
    Is there a difference in the 14FF housings for the different carriers? I would think the housings are the same and that if I were swapping the carriers as well as gears than it wouldn't be a problem...
    67 Camaro 468
    68 CamaroSS 327
    89 K5 Blazer
    98 Pontiac GTP
