14FF disc bracket question...
Discussion in 'The Garage' started by Thumper, Oct 22, 2003.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I apologize if its been asked, but didnt find anything on search:
    Do all the disc brackets require a spacer between the axle flange and the bracket? Or is it just a matter of seeing if you need one when you bolt them on? What size spacers may be required? I have the brackets made according to drawing, out of 3/8 plate, and they are ready to bolt on tomorrow.
    Mike
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Using a standard 3/4 or 1 ton SRW 14FF will require 3/4" spacer or spacers if you use 4 little ones instead of one larger ring. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    sky's off road design (use to be sky manuafacturing) has a new 14ff bracket that is bent so no spacers are needed.
    -Jeremy
