14FF Disc?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Triaged, Feb 2, 2002.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Did you have to grind down the head of the wheel lugs in order for them to fit the rotor? Or is there another lug out there that has a smaller head?
    Too bad they won't fit in my drill or it would be done by now.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    ok im not familiar with the 14 bolt's,,but doesn't the rotor just slide over the lug's ? why would you need to grind the head of the lug ,on the back side of the axle face,for the rotor to fit ? there are several different size lug's for trucks and cars. they should however be the same if your going from drum to disc,,you didn't change the axle.
    <font color=purple>ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]</font color=green>
  3. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    On a 14FF the rotor (or drum) goes inboard of the hub. The studs go thru the rotor than thru the hub just like the front does. The recess in the rotor for the lug head is too small for the lug and front lugs are too short to use.
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Thanks.
    I will search around and see if there are any "off the shelf" lugs out there. I think for that much $$$ I'll just grind their heads down. I'm too cheep and all these mods at once are killing me.
