14ff DIY4x disc conversion ?
Discussion in 'The Garage' started by jayweb, Jun 26, 2006.
  1. jayweb
    jayweb 1/2 ton status
    Jul 6, 2003
    213
    NC
    trying to mount up my calipers (using the 10b fronts) and the caliper hits the bracket - with one caliper bolt in - it will not slide down far enough to get the other bolt in - anybody had similar situation - I was under the impression that 1/2 & 3/4 10 bolt calipers were the same - should I grind the caliper or the bracket?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Could the brackets be different? Try the other caliper on the bracket...
    Mayeb that will help.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    There is a little thing on the caliper that needs ground down. In my experience, the D44 calipers have been direct fit with no grinding.
  4. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    We fit the caliper brackets to a D44 Caliper. Seems there is a good bit of variance in the caliper castings. You can do a little grinding on the caliper and/or the bracket. Make sure your sliding it in straight though. Don't put in either caliper pin until both will go. We do keep them as tight as possible so you can fine tune as needed. No sense in making them too big and then not have any options left.
  5. jayweb
    Jul 6, 2003
    213
    NC
    thanks guys,and Kert, it looks like a little grinding the nubs on the calipers will do the trick.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    We had to grind a little on the brackets.
