14FF E-brake cable fix
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tori89k5, Feb 3, 2002.
  1. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    USE THIS LINK IF PHOTOS DONT LOAD FOR YOU
    http://community.webshots.com/storage/1/v1/2/64/65/30526465ppVTbQpwRB_th.jpgmy original cable has no chance in fitting.... or being retained...
    So I came up with a way to retain the cable without totally butchering everything. I removed 1/2 of the cable braket from the cable on the donor truck, and will use this for support of the cable. You can bolt this in place on your new 14 bolt, but its not totally necessary. With a dremel tool I then removed the retaining cage on the 10 bolts cable. as seen in this picture...http://community.webshots.com/storage/1/v1/2/70/71/30527071CfDLBIUYoH_ph.jpg
    <a target="_blank" href=http://community.webshots.com/storage/1/v1/2/71/75/30527175yOPvllrtZg_ph.jpg>http://community.webshots.com/storage/1/v1/2/71/75/30527175yOPvllrtZg_ph.jpg</a>
    This worked well, the cable is still adjustable like it should be and if you ever have to replace the cable you still can. The only thing you have to do is remove the spring steel cage. I put a small tack weld on the cable housing to the piece of pipe just to hold it in place, but the tension of the cable spring will hold it against the pipe.
    1990 K5 4" lift, 33's, 14FF Detroit locker, D44 w/ posi, 4.10's Raptor Tranny and Velvet Rides....
    &lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by tori89k5 on 02/05/02 01:55 AM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by tori89k5 on 02/05/02 02:02 AM.</FONT></P>
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    hey tori thanks for the email and i tried to check the pics but it says i am forbidden on this server or something...im trying to get into the pics so i can see it...
    Later
    Just tap it in...tappity tap tap...
  3. tori89k5
    Apr 12, 2001
    946
    Is anyone else having trouble seeing these pics ? If so,... let me know directly at my reg. E-mail addy. and i can send them to you.
    TJM52071@cs.com
    Hope this helped somebody....
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I can't see them either.[​IMG] Just to let you know that a 14ff out of an 80's 1 ton the e brake will work since the cable crosses over so both connect on the drivers side.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    My 14 ff is out of a 83 1 ton but my e brake cable doesnt just bolt up...that was the problem i was having...my 88 10 bolt had a different style of attachment for the e brake cable...
    Later
