14FF fluid
Discussion in 'The Garage' started by guz71, Jan 1, 2007.
  1. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    How fluid should i pour into my 14ff? I did a search and didnt find anything....sry noob.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    around a gallon. Just fill it until it comes out the fill hole, then lift the pass side tire and let the gear oil run down to the drivers side wheel and fill again.
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    that and another good tip I read was if it isn't in the vehicle yet just tilt it on the jack stands so that the pumpkin is facing down (the diff. cover will be parallel to the ground) then fill it up...that way it gets the most fluid possible. It'll fill up the tubes and the pumpkin...then just rtv the cover and bolt it back on...
    -Avery
  4. guz71
    Sep 17, 2006
    387
    lubbock/houston
    thanx guys, my shackle kit from di4x just came in so im finally going to be done for now
