14ff gears
Discussion in 'The Garage' started by neverendingproject, Jan 9, 2007.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Do they need to be reset if you replace the carrier bearings?
  2. goldwing2000
    goldwing2000 Guest
    Just the backlash.
    If you put the adjusters back the same amount they came out, it should be pretty close.
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Should be OK, but Id run a pattern just to be sure...
