14FF housing tube diameter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Jan 17, 2002.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Could anyone tell me the diameter of a 14FF housing tube?
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  2. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I can tell you my SemiFloater is 31/2". Does that help?
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Eye-ball with a ruller shows just under 3.5"
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    The axle tube diameter is 3 3/8" for the 14 bolt FF.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Hopefully this helps. BDS lists for a 77-87 3/4 ton 4x4 (which houses a 14FF rear) rear ubolts....P/N 040032, Diameter is 5/8", Width is 3 5/8", length is 10", and they are the round style.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I second what Rene said. 3 3/8" is the diameter of the tubes.
    I will bet you a million dollars that it IS that measurement. [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I called the dealer and told em what I had. 1979 K20 pickup Corp 14. They told me it was 3 1/2. Does the year make a difference?
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
  8. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    So, I have 3 3/8 and 3 1/2.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  9. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I'll add another measurement of 3-3/8" to that tally....that's what I measured off my 14BFF.
    I cut a 3-3/8" hole template for new spring pad mounts and it fits perfectly. Not too tight, and not too loose.
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  10. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Why do I have this feeling that the parts boy at the dealer was smoking something funky?
    SK-15
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ok, I did what I should have done the first time. I took a pair of "C" jaw vise grips and tightened them down till they would drag just a little back and forth across the tube, then measured the opening. 3 3/8" exactly. When I "eye-balled" it earlier, it looked like just under 3.5 but just over 3.375. Obviously it was an "optical conclusion [​IMG]
    Russ
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Because he was and he does not give a crap what the actual true diameter is. He just wants you to leave him alone so he can concentrate on getting his BUZZ!!! [​IMG]
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Russ, you mean 3 3/8", not 2 3/8". [​IMG]
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Of course, that's what I said... You should read more carefully... {rolling eyes up to ceiling and whistling casually}
    Russ
  15. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    And why does Leadfoot say
    "Diameter is 5/8", Width is 3 5/8", length is 10"
    3 5/8?!?!?!
    Argh!! Cornfused!!!
    And WHERE do you get some size like that?!? I went all over, NAPA, CarQuest, AutoZone, etc and NO ONE has 5/8, 3 3,8 or 3 5/8 and 10 long!!! Where do you people get these at? I don't want to buy them from the dealer for $20 EACH!!
    SK-15
  16. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Go to Farm and Fleet, thats where I got mine. The 5/8" is the diameter, the width between the 2 legs should be 3 3/8" and the length should be about 10".
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  17. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Where are you measuring "between" the legs? From the middle of the post to the middle of the other post? Or from inside of the post to inside of the other post? Or from outside to outside?
    I did not see at F&amp;F anything labeled 5/8 3 3/8 and 10". I found a 9/16 one that was close....but not the 5/8 that this axle is gonna need!!
    SK-15
  18. Leadfoot
    Nov 28, 2000
    3,112
    I never measured my axle, but I am looking to replace the lift blocks with lift springs and needed to order new u-bolts. I looked at the BDS website click here
  19. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Look in the yellow pages for a spring company.
    I got mine for $10 ea.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  20. outlaw612
    Feb 11, 2001
    2,342
    I measured from inside to inside.
    I got mine at the F&amp;F here in Urbana when I did my swap. I dont think mine were that long though. I did the shackle flip on the rear so I just measured from the inside of the rounded end to the tip of the legs. (I want to say about 6 inches but Im not positive on that. )
    I can look at my reciepts, it might list the part # or something.
    Another thing, If you look at the back of the package they have a list of all the sizes or how to order what you want.
