14FF Hub bearing question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Oct 3, 2001.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Does the outer race for the outer bearing on the hub need to be pressed in or is it held in by the big snap ring? .......do I need to take it to a shop?? Thanks.
    My K5 Buildup: <a target="_blank" href=http://www.geocities.com/xci10u2/K5.html>http://www.geocities.com/xci10u2/K5.html</a>
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    pressed.
    a seal and race driver and a hammer to put it in.
    snap on sells a long punch with a football shaped head for removing races. most everyone uses a large screwdriver, but i liked the snap on thing so spent the bucks
    <a target="_blank" href=http://www.lislecorp.com/tools/catalog/bearings/bearings.htm>here</a> is a link to seal and race drivers
  3. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    After you pull out the snap ring just knock the old race out with a punch. Drive the new one in past the ring groove. Install the snap ring. Then tap the race back to flush against the snap ring. This is what my gm service manual says, and it worked well for me. It shows a special tool for pushing it back against the ring, but i did it with a punch. Just my thoughts.
    eric
    Don't get me started, you know how i get.
    82k5, 14bff, d44, sm465, np205, 300hp350, rust
